Hi. I have a pair of Russound CAM6.6s with both Uno-S2 and Uno-TS2 control panels installed. I have a SRC2 remote control. If I try to use it to control a S2 panel, no prob. If I try to use it to control a TS2 control, problems. I can turn the TS2 on from across the room. But that's it. When I push a button on the controller, I see the little blinking led just above the screen on the TS2, so it seems that it is seeing the signal. But no mute, no vol control nothing. Until I get within about 3 feet. Then it all works. I have replaced the batteries in the remote 2 times. And like I said, everything works on the S2 keypads. Of course, the room I want to use the remote in has a TS2 pad.
Anyone have any ideas? I updated the programming when I installed the system about 8 months ago. This is a DIY job, but I bought the update cable and updated everything. I am running 2 ipods on the system with the TS2s working flawlessly. But this error I don't get.
Thanks in advance for your thoughts!
Slider5150
Slider5150
