1 - 5 of 5 Posts
Not sure if I'm doing something wrong or if its not set up correctly but I can't get the surround mode to change from STRAIGHT . According to the manual it says if the SUR DECODE button is pushed it should change to pro logic,PLIIx movie / music / game / neo 6, but nothing happens. It just displays SUR DECODE STRAIGHT all the time. Thanks for any input
Are you watching something that has 5.1 sound? PLIIx only decodes 2 channel audio. Flip open the remote and push the Info button. If it says Dolby Digital it is playing 5.1. Straight decode means you don't have any DSP modes turned on (movie, live entertainment, live club, etc.)
I hope you're enjoying your new 2030. I have the 2020, and I love it. Cheers!
1 - 5 of 5 Posts
