Status
Not open for further replies.
1 - 5 of 5 Posts
Hi,
I just recently put together my first home theater and I'm having some problems getting the receiver setup.
My current system is:
Tv: Samsung HLR5067
Receiver: Yamaha RX-V1500
DVD player: Sony DVP-NC665P 5 disc changer connected via component and optical (to the receiver).
Speakers: Axiom (c) VP150 , M22ti (surrounds), rear surrounds (QS8)
Subwoofer: SVS PB12-ISD
For some reason the receiver didn't come with the YPAO mic so I had to call the place I bought it from for them to order it for me from Yamaha. In the meantime, I got a Radio Shack SPL meter to calibrate everything. I've followed all of the instructions and everything seems to be working fine.
The problem comes when I try to watch a movie. I'll go to the audio setup and choose the Dolby Digital setting but the receiver never recognizes it. I'll manually change the receiver but I still only see the front left and front right speaker displayed on the little screen on the receiver. It's my understanding that the receiver should automatically detect which signal it's receiving and change the setting for you (I have the dvd setting set to autodetect on the receiver).
Then when I pop in a DTS movie and choose the DTS track, it'll automatically switch to DTS for me and everything sounds awesome (I also see all the correct speakers lit up on the little receiver screen). Then when I change back to
Dolby Digital the same problems arises again. For example, I'll have the volume set to -10.00db to see if the Dolby digital signal is working correctly. Then when I switch to DTS and leave the volume level at -10.00db it's just WAY loud and I have to turn it down. Obviously I'm not getting the dolby digital signal.
Since the DTS function seems to be functioning properly, I'm pretty sure all the speaker connections and everything is working fine. So I'm thinking there is some obscure setting that I'm missing on the receiver itself. But I've been playing with it and going through the setup process for 3 days now and I still can't solve the problem.
Also, I have the speakers set to small and the x-over set to 80hz.
Any help would be greatly appreciated.
....did you check the audio settings in the menu of the DVD player to make sure everything looks correct and properly enabled there for DD?
Is the movie a DD 5.1 or just DD 2.0?
I notice the same thing on my RX-V1500. I does it on some DVD's with DD. If I put Fifth Element on, it only shows two channels but if I put on Lord of the Rings it will show all usable channels. If you look on Page 36 of the user manual under NOTES. It will talk's about detecting the signal flag
"Some 6.1-channel compatible discs do not have a signal (flag) which this unit can automatically detect. when playing these kinds of discs with 6.1-channel, select decoders (PLIIx Movies, PLIIx Music, EX/ES or EX) manually."
I was wonder if the system was set to 5 speakers instead of 6 would it detect the signal flag correctly. This something I'll have to check when I get home tonight.
1 - 5 of 5 Posts
Status
