1 - 4 of 4 Posts
hello all,
So, my brother accidentally plugged my receiver (RX-V2065) into the 220V power plug and I saw smoke came out; fried the receiver.
I bought this from Best Buy less than a year ago along with a 4 years protection plan. I am not sure if they can fix this. Otherwise, I might get a replacement under the protection plan. However, I heard that they no longer stock this model and replaced with RX-A2000.
Will take it in this weekend and see what they can do. I don't really want to replace with something else. I love this model (v2065).
Well, first see what your options are, then come back and report. I did not think 120 volt plugs fit into 220 outlets...
My opinion here.
I think the RX-A2000 would be an upgrade to what you have now.
Discussion Starter · #4 ·
I still like the V2065. Maybe I am used to it. I also heard too many issues on the A2000.
Will see what they can do when bring it in this weekend.
Thanks for all your opinions.
1 - 4 of 4 Posts
