Hi,
I was wondering which output do you use to connect the RX-V2400 so that the TV speakers can also play the audio signal? or does no-one do this?
I use the "Tape REC" output, but if the TV is already on, and then I power on the RX-V2400, I get a bit of noise on the line as the RX-V2400 comes up.
So, maybe I am supposed to use the line out for one of the other zones?
BTW, does anyone else have this "noise" problem? Could someone with an RX-V2400 check this irregularity for me?
Hobbieman
Hobbieman
