I'll just excerpts from my other threads... I don't know what's wrong with this website. It won't let me post a link to my thread or post pictures of my problem.
I am only using the S-video with the Red and White and Yellow unplugged. I even tried what someone suggested, to unplug the Coax to the LNB in of the CS5K to see if it is a coax problem, but the interference still occured. My cables are all very clean and gold plated, I've tried repositioning the CS5K to other tables, away from other IRD's etc and same thing so long as I use S-Video.
Using something like an HDMI is impractical because the CS5K doesn't even support it, and even if it did it would be of no benefit being we're receiving Mpeg2 Standard Def signals heavily compressed. I would just discard the S-Video altogether and use the Component outs (which I heard was a remapped version of the S-Video) but unfortunately my TV only has S-Video and Composite Inputs. My other TV does have Component input, but that is being used by a dvd player. It's really a shame because the RCA connections really produce an unbearable picture for me.
The most common problem solution I have read regarding my situation was something called the"ground loop isolator". I'm not too familiar with it but I'm reading about it. I was thinking of going to Radio Shack to pick up a Composite to S-Video converter. I was thinking I'd use the CS5K's Composite out into the C-S converter and plug that into my TV's S-Video. If not, I guess I'll have to try the ground loop isolator (shrugs)
I have plugged both 5K's into different houses, different tv's and moving the 5K to a table all alone away from other components. I tried unplugging everytihng except the TV and 5K to no avail.
I have tried 3 S-Video cables thus far. All 3 of them work on my subbed IRD's. I have used the gold plated, and alloy or silver plated.
And to the last poster, Composite is the worst. I think you're referring to Component which is the step up from S-Video. I don't have Component inputs on one of my TV's and my DVD Recorder doesn't have them either. S-Video is the best option for me and now I can't record anything because of the bars. Such a shame. I can't even watch TV using these cables because of the bar, I have to use composites which is just truely an ugly picture I cannot bear to look at.
It's apparent that the Coolsat engineers put no effort into making a quality built IRD. Many people are having the same problems as I using Computer video cards and it happens to specific brands so I suppose it's just a bad design or something if it's happening to specific brands and not others.
