I would definitely try the cables first.
No need to spend a bundle, just get couple of video cables that have RCA terminations.
The other day at *gulp* Walmart (hey cut me some slack - I was in a jam), I picked up a 6-ft Phillips PH61071 component video cable for ~$9. You could get one of those and split up the leads and have three cables - although you need only two.
Otherwise, most any video cable with the right ends should work.
Not all audio cable is coaxial design and doesn't always work well for digital signals. I was having a similar problem with a different piece of gear and had been using a "quality" audio cable, but was getting those occasional dropouts. After much messing around, I came to find out the cable I was using was made from shielded twisted pair. I whipped up cable from RG-6 using F>RCA adapters and problem solved.
