I am a newbie to multi-channel audio. As I understand it, most SACD and DVD-A players utilize fixed crossovers for the LFE channel, which are typically set at 80 Hz. For 5.1 movie soundtracks, I have a set-up with an external electronic crossover. On my pre/pro I set the subwoofer to OFF and the main L/R speakers to LARGE, which routes all the LFE to the main speakers. Then I use the external crossover to set the high-pass to the main speakers at 60 Hz, and then low-pass and gain control on the subwoofer is variable and I have it dialed in a little south of 60 Hz right now. I'm wondering if I can use a similar technique for multi-channel audio?? Does anyone else use a similar configuation?
-TBain
-TBain
