Hi folks,
I have a credit at Samash and I was thinking about grabbing a Power Amp., in order to get into the separates world, for a better sounding experience.
According to several reviews, my first choice is the BEHRINGER A-500, which seems to be the best bang-for-the-buck.
Problem is that Samash does not carry such model (only the 1500 & 2500).
Well, after googling thru their site, I've found the SAMSON SERVO SERIES, which seems to fit my bill and also my needs.
I'm now torn between the SERVO 300 ( 100w x2 @ 8 Ohm ) and the SERVO 600 (225 x 2 @ 8 Ohms).
The 300 costs $ 200, while the 600 is $ 279.
My AVR is a Denon 3806, so even the 300 model would suit my needs, but a bit more power sounds better, though. By the way, my speakers are all 8 Ohm rated.
As an additional info, I've never had a separate before, so my questions are:
Is the SAMSON a good option?
Isn't the SERVO 600 a bit overkill, if compared to the 3806 power rating?
What about their overall quality, if compared to the BEHRINGER A-500?
Well, I'd really appreciate for any further comments on such, in order to make up my mind and to decide what's thew best way to go.
To be honest, I'm not even sure that I'll have a sound improvement by adding a separate, although I truly believe I will...
Cheers / Avliner.
Cheers / Avliner.
