Status
Not open for further replies.
1 - 7 of 7 Posts
Hello everyone, just got my DCT5100 from Adelphia hooked up to my new HNL4365. What should i have the output of the Moto box set to - 1080i or 720p? I understand that most of HD is broadcasted in 1080i, but I believe that the native mode for the DLP set is 720p, hence the dilemma.
Second quick one - I have read the post on this board where one member has his cable split and he feeds his analog channels directly into TV on an antenna input for the analog channels (under 100) - does anyone else have a similar setup or can provide comments on this?
Thank you in advance,
Steven
Premium Member
You'll want to set the box to output 720p.
1080i signals will be scaled by the box.
If you set the box to 1080i, those signals
would just be scaled by the tv set itself.
BUT if you set the box to 1080i then 720p signals
would be scaled to 1080i by the box and then
scaled BACK to 720p by the set, which is BAD.
You want 720p to be passed with no scaling.
Discussion Starter · #3 ·
zvgot - if the box is outputting 1080i and the signal is in 1080i - why would the box do any scaling?? I understand your point about 720p signal thought, but all the channels that I will be watching are in 1080i except for ABC.
Premium Member
I think you misread my post. If the box is set to 1080i then 1080i signals
WON'T be scaled by the box. And I didn't say they would be. I said they
would then be scaled by the tv set. When I said 1080i signals would be
scaled by the box, I was talking about having the box set to a 720p output.
I've reread my post and I'm not seeing any inconsistencies.
The 1080i signal will have to be scaled SOMEWHERE. When the picture
reaches your eyeballs your set is only delivering 720 lines of resolution.
I suggest the following for the split for PIP:
-split the cable before the 5100. run one cable into the 5100 and one into the ANT input (A or B)
- run component from the 5100 to the HLN
- also run s-video from the 5100 to the HLN
This will allow flexability on PIP. When watching HD, you can put the Compnent input on the big screen and ANT in the small screen. If you want side-by-side PIP (non-HD only), you can put ANT on one side and S-video on the other.
justman,
That's a great idea (running the s-video as well) for PIP flesibility. Hadn't thought of that (haven't had my set long enough to run into that issue). Does splitting the cable PRIOR to a box make that much of a difference vs using the cable out on the box? (I've unfortunately got the SA300HD).
Ben
1 - 7 of 7 Posts
Status
