Rich,
The software uses test patterns generated from a DVD. My player is connected via HDMI, and, when HDMI is used the "Hue" adjustment in the Sammy is greyed out. I left all my settings on the DVD player to "0". I believe this is about as neutral of a source that is easily obtainable.
The color temp is one of the first adjustments you make. My understanding is the color temp is just a rudimentary grayscale adjustment. The software has you check all color temp settings, and then suggests the closest to the target grayscale. In this case it was warm 2. All other adjustments are done after setting the correct temp, so this leads me to believe it is the most critical.
Rick
Originally Posted by RMSko /forum/post/0
Thanks for posting this. I noticed that you are using standard/warm 2. Do you find warm 2 to provide a better picture than warm 1? Did you do any calibrations with warm 1?
Also, I was thinking of buying the SpyderTV, however, am I right that it will really only calibrate the DVD player since it needs the test patterns in order to calibrate? If I am right then I probably won't get it. What I really want is something similar that would calibrate my HDMI input being fed by a DirecTV HD TiVo.
Rich,
Rick
