1 - 20 of 320 Posts
77" A80J, 48" LG C1, X4700H, 5.1.2 Infinity Primus + Bic PL200
Not much info on them yet. Just came out. Thinking of picking one up for a bedroom tv (43in). Trying to find out the difference from the D series. It says improved black level, but thats all Ive seen so far. I wonder how the buzz is, and if it has brightness pops.
Seen them at a few websites and HHGregg for $499.
There is a very basic review out there, but cant link it.
Updated info.
Picked up the PN43E450 for a bedroom tv. Here is my quick review.
Happy to report no brightness pops, and no excesive buzzing (its there, but you cant hear it unless you are dead center, close, and are trying to hear it). For a low end plasma, has a better then average picture quality and black levels. Speakers actualy arent bad either. Plenty enough for a bedroom TV, though youll obviously want a real surround setup for a living room or home theater setup.
Was able to get mine for $405 + tax. Going rate is $499, and sale prices are about $449. At $450 or less, I dont think there is another TV better in the price range.
Pictures
Stand Installation
Ports
Remote and Items
Out Of Box
After 15min Simple Calibration
Ill try to get some better pictures later. There are lines that show up in the pictures, and not sure why.
15 minute calibration settings with Lagom test, for no ambient light bedroom viewing. Using HDMI from laptop output with Intel HD3000, 1920x1080 @ 60Hz (letting the TV down-convert).
Mode - Movie
Cell Light - 14
Contrast - 93
Brightness - 44
Sharpness - 0
Color - 55
R/G Tint - 50/50
Color Space - Native
White Balance
RO - 21
GO - 28
BO - 22
RG - 20
GG - 27
BG - 23
Gamma - -1
Dynamic Contrast - Off
Black Tone - Off
Flesh Tone - 0
Color Tone - Warm1
Size - Screen Fit
Digital Noise Filter - Off
HDMI Black Level - Low
Film Mode - Off
Discussion Starter · #2 ·
Just wanted to follow up on this. I got someone I know to buy one of these and hooked it up for them. Its a really nice looking set, no brightness pops or buzzing in the short time I watched it. Didnt have any good material to work with though.
Not sure how much better it is over the D450, having only seen them in stores. But I do feel there is a difference, though small.
I plan to pick one up soon for my bedroom. I just dont think there is a better TV in the price range.
Looks good, wonder if you can enter service menu and change it to an e7000, etc.
The D450/D490 you can go into the service menu and change it to a d7000 to get day/night modes and the 10 pt greyscale. Also you can get cinema smooth. If you can do this on the e450 this year this will make it definitely best bang for your buck model.
Would appreciate some pictures of this set. Don't really trust the stock photos or the specs which usually has errors.
From the stock photos, it looks like they changed the stand of the E450 to a thicker foot. Also, it looks like they removed one of the component inputs, down to 2x HDMI, 1x component (shared composite). Can someone verify this?
The E490 stock pictures looks pretty much the same as the D490, but in the specs they also seemed to have removed 1x component + VGA input. They also seemed to have added LAN input though.
Discussion Starter · #7 ·
Im not sure what all the D series had or looked like. The person I set it up for had it mounted, so I didnt get a good look at the stand. Its a big rectangle type though.
One Component input, 2 HDMI, and one or two composite, didnt check those.
Picture quality is good for the size and price range. Screen is very reflective, so have it in a dark room. Itll be in my bedroom where I only watch stuff at night, so Im not worried about that.
Im happy to report that I watched 24hz 1080P blu-ray on it tonight with HDMI set to "low", and there is no brightness pops. Also, no audible buzzing either.
Needs some calibration out of the box. Skin tones are a little orange-ish, but not as bad as many. I didnt really have anything to calibrate with, so did some basic cell light, brightness, contrast, etc... stuff and got a pretty nice picture. Blacks seemed to blend, didnt have enough time or tools though to get the contrast and brightness fully right.
So is that a non-swivel base? Not sure why Samsung would do that, seems like a minor step backwards in design compared to last year's.
Discussion Starter · #11 ·
No swivel. Im guessing cut back on that to save cost for the other upgrades. Thats why it still sells for the same price.
They have apparently lowered the lines of resolution from the D450, as the 51E450 now has 1024x768 native resolution vs 1360x768 for the D450. Not sure if this has a major impact on picture quality, but if it is important to you, then you may want to hurry and get a D450 while there are still some available on closeout.
Discussion Starter · #15 ·
A few months ago when I was looking at the D series, they had 1024x768 as well. Some sources incorectly listed them as 1360x768. The large sizes may have had 1360x768, but not the 43. If they did, I would asume the same would have carried over as the difference are minor.
It still accepts a 1080P signal too. Just down-converts it, and does so without messing up the aspect ratio.
The 43D450 has 1024x768, and the 51D450 has 1360x768. Apparently, the 51E450 is changing to 1020x768, but not sure if this will have a major impact upon pic quality. Just wondering, will have to go check one out in the store.
Thanks for the pictures CTM Audi, really appreciate it. Just wondering are there any inputs (HDMI, USB) on the sides of the panel?
The E450/E490 has popped up on Samsung's Office Site .
NEW 51" Class (50.73" Diag.) Plasma 490 Series TV PN51E490B4F
NEW 51" Class (50.72" Diag.) Plasma 450 Series TV PN51E450A1F
Looks like the native res for the 51" set is 1024x768 now, which I hope is really a typo. Looked at the User Manual for the PN51E450 and it also states 1024x768. They don't seem to have a proper user manual for the E490.
This is disappointing for me because I intend to use this for HTPC purposes, and want 1-to-1 pixel mapping (square pixels). Panasonic went to 1024x768 for their 46/50" 720p sets couple years back. Guess Samsung finally moved to a lower res panel to reduce cost and power consumption as well.
It also looks like they removed one of the component inputs for the E4xx series as well, but didn't seem to add any extra HDMI inputs. For the E490 they list 2 HDMI which I hope is an error because the D490 had 3 HDMI (2 back/1 side). It looks like they might have removed the VGA input as well, which is very useful, but added a LAN input which I personally don't have much use for.
I guess I might pick up the older PN51D490 if the price on it drops some more, back to around BF levels. Or else spent some extra money and step up to 1080p panel E530 or Panasonic ST50 series.
Thanks for the review have a 42 inch nad 54 inch high end PANNYS but gonna pick up the 51 inch model of this tv for my GF's bedroom 20 inch's from 12 ft doesnt cut it for me LOL!
I believe it was the same last year where they incorrectly published 1024x768 as the resolution for the 51D450. I can't see the logic in building a whole new production line for a lower resolution TV which frankly will not even be viewable at that size, and as a result will sell far less units. I'm willing to bet it is the same 1366x768 panel as they are using on the 51D450 but with updated firmware, probably with the FBr fixed/optimised as the rest of the E range and D range is with the latest logic board f/w.
What I need is someone with 51E450 logic board f/w to extract it so that I can put it on my 51D450
My friend has the 51" from HH Gregg at $599.
Used the Rock Band 2 guitar for XBox 360 over HDMI to do autocalibration, video input lag was 35ms with game mode on and 31ms with game mode off. Go figure.
The specs say non square pixels and I looked at them really closely and think I could tell they were wider than squares, but maybe I was seeing what I thought I should be seeing.
I wouldn't buy a set with non square pixels but I admit for just watching HDTV both his 51" and a 1024x768 Panasonic 42" plasma I watch sometimes are great looking.
I am going to bring over the Aladdin DVD to run THX optimizer and will report calibration. I am even thinking of spending $6 on the blue filter glasses that work with the THX optimizer. Any opinions on whether it would be $6 well spent?
1 - 20 of 320 Posts
