1 - 2 of 2 Posts
I was hoping you guys can give me some idea's. I'm trying to help my buddy hook up his xbox360, it has component cable and not the HDMI. On his tv it is hooked up with component cables, and it works ok.
I switched the switch on the xbox360 to hdtv and it now says on the tv. "not supported mode" with blue screenn.
How do I get it to work on 1080p ?
Discussion Starter · #2 ·
Nevermind, just figured it our. TV is only 1080I and when xbox 360 was set to 1080p the tv could not get the signal.
Sorry for the post it can be deleted if need be.
Questions for myself. What si the best 50" TV money can buy right now?
Thank you!
1 - 2 of 2 Posts
