1 - 3 of 3 Posts
Discussion Starter #1
Yesterday I turned my xbox360 on and the Component input didn't show a signal. I was sure it was my xbox until I switched its cables into the other component inputs. Everything worked fine. Same thing with my HD cable box. So, it appears one set of inputs is dead. Any idea why one set of the components would have crapped out? The TV simply says "Searching for Signal" then "No Signal" when I switch to Component2. Is there some sort of factory reset I could try?
1 - 3 of 3 Posts
