1 - 4 of 4 Posts
· Registered
I don't have any flicker issue.. but I can't seem to get the picture within the borders of the TV... The picture size option on the remote doesn't work the same way as in VGA mode.. it only shows 16:9 and 4:3 option with HDMI.. and there's no picture re-size option on Nvidia control panel.
Please help me.
· Registered
Discussion Starter · #4 ·
okay, I installed the new drivers and use the new resize feature but for some reason it only brings in the borders a half an inch.. even if I slide the slider bar all the way in.
I can't see the clock are the start menu.. half of my desktop items I don't have access to because the screen has them cut off.
1 - 4 of 4 Posts
