1 - 3 of 3 Posts
Hello my name is Edwin and i have question.
I have the 65F9000 it is a great TV but, sometimes when i put my Ps4 on then i have no picture.
I have changed from Hdmi 2 to 3 but no difference.
I buy a new Hdmi fast speed 3D 4K bla bla but the problem is stille there.
Before i had a Panasonic plasma and there was no problem.
Pse help?
Originally Posted by edwin 40  /t/1524224/samsung-65f9000-and-ps4-problem#post_24526962
Pse help?
I do not have a F9000 at home but I have installed a F9000 55" and tested it with my PS4 and PS3 without any problem.
Can't remember which hdmi port I have use.
Do you have no problem with the HDMI #1 ?
I think there is also the possibility that one of the TV entry HDMI is CEC, so maybe you can check this and disable it to see if it solves the problem.
Did you also have a selection for the Video screen option on your PS4 : 1080p (forced for example) and not "Auto" ?
Discussion Starter · #3 ·
DplanetHD
Ok i check the video screen option.
What do jou mean with ( I think there is also the possibility that one of the TV entry HDMI is CEC)?
I have not try the Hdmi 1, i have connect my tv in 1.
1 - 3 of 3 Posts
