1 - 3 of 3 Posts
· Registered
Am I the only one who doesn't like the IR performance of the IR receiver on
LN40A750 TV ? If I don't point exactly on the TV it doesn't work.
My Xantech receiver picks up the signal all the time in any direction
but the TV doesn't. I even tried to set up blaster near by but it still
doesn't work properly
Also tested with AllinOne remote - same problem
Harmony 880 much better but still not perfect.
(Yes i installed new batteries to make sure)
Any ideas ?
· Registered
I have an LN40A530, pretty different TV but I am also having issues with the IR receiver performance. Basically if I'm outside of 30-45 degrees from the center line or up or down it won't work. It's pretty frustrating. Have you had any luck with this issue?
Ivor
1 - 3 of 3 Posts
