Hi Everyone,
I just upgraded my receiver to a Pioneer 1120-k and have been noticing some issues on my LN52B750. I'm sending everything to HDMI 1 on the sammy and up converting everything going to the 1120. I started noticing what at first I thought was missing frames or laggy picture when watching netflix streaming on xbox. The picture would lag for a few ms over a period of a second, then fine for 1-2 minutes - it's a very intermittent problem. PS3: netflix same issue (a bit less). XBOX gaming: similar issue when playing Halo Reach. Sometimes repeatable in certain areas of multiplayer maps (maybe due to rendering issues). OTA is perfect.
After much research, I have finally found an example of what I am seeing here:
http://www.youtube.com/watch?v=wXTsF_cScKA
My issue is not nearly as bad as in the video. There is a thread at CNET where customers are describing the same issue here: http://forums.cnet.com/7723-13973_102-379599.html
I'm not sure if the 1120 is doing something to the signal - I originally had video signals going directly to the 750 via HDMI and audio via optical to my old receiver. I never experienced any of these issues in this setup. ...or maybe they were always there, but I never noticed? New gear always heightens my attention to detail.
Some other settings:
Blur: 10
Judder: 0 (sometimes 3, which helps)
HDMI Cables: Amazon frustration free
1120-k: Up conversion on/off -- doesn't make a difference
Sources: OTA (COAX straight into tv), xbox, ps3, macmini HTPC (ripped DVDs).
So, is this something inherent in LCDs? Something particular to 750 series? A warranty issue?? Any guidance would be helpful.
Blur: 10
