Samsung 8 Series, wall mount issues
1394 Views 4 Replies 4 Participants Last post by  aydu
I bought the official samsung wallmount when I bought my TV (Mount model # WMN1000B). However this mount requires you to have studs 7" apart to mount. Code is 16 inches in america.
How am I suppose to mount this? Samsung's support has given me no help.
1 - 5 of 5 Posts
if you read what it says on instructions..
it says on there only one has to be attached to stud the other is fine without it.
Or, you can mount either plywood or wood anchoring strips to the 2x4s and the mount to those.
...or you can return that mount and buy one from Monoprice that works on 16" centers at a fraction of the cost.
Best option so far.
1 - 5 of 5 Posts
