Samsung Discrete Input Remote Codes
437 Views 4 Replies 3 Participants Last post by  buttonmasher
Hi,
I just picked up a 2796 and so far I like it alot:). My only issue is that it doesn't seem to support discrete remote codes to select the inputs. On my Toshiba, I can program macros on my remote for each component so that my family can switch between inputs with one remote key. Does anyone know if the Samsung TV's have discrete codes for each input?
Bob
Status
Not open for further replies.
1 - 5 of 5 Posts
As far as I know, Samsung doesn't have discrete remote codes for ANY of their products. Which sucks. Because I have a Samsung HD Receiver, and it is the ONLY component in my system for which I can't use discrete codes.
That really sucks. I have the "top of the line" Samsung TXM2798HF and I suppose it does not have descrete codes either.
How the hell do they get away with that? If I had known that I would have purchased a different set.
Does anyone know of a good switcher that will do component, s-video, and RCA (and upconvert to component)?
buttonmashere,
I saw this posted somewhere for Samsung HD receivers ... maybe they will work for you (Pronto codes)...
Don, you beat me to it, but here they are for the Pronto users courtesy of John Fine"s MakeHex:
Device Code: 9.9 Function: 152-On
0000 006D 0000 0022 00AC 00AC 0015 0040 0015 0015 0015 0015 0015 0040 0015 0015 0015 0015 0015 0015 0015 0015 0015 0040 0015 0015 0015 0015 0015 0040 0015 0015 0015 0015 0015 0015 0015 0015 0015 0015 0015 0015 0015 0015 0015 0040 0015 0040 0015 0015 0015 0015 0015 0040 0015 0040 0015 0040 0015 0040 0015 0015 0015 0015 0015 0040 0015 0040 0015 0015 0015 070A
Device Code: 9.9 Function: 153-Off
0000 006D 0000 0022 00AC 00AC 0015 0040 0015 0015 0015 0015 0015 0040 0015 0015 0015 0015 0015 0015 0015 0015 0015 0040 0015 0015 0015 0015 0015 0040 0015 0015 0015 0015 0015 0015 0015 0015 0015 0040 0015 0015 0015 0015 0015 0040 0015 0040 0015 0015 0015 0015 0015 0040 0015 0015 0015 0040 0015 0040 0015 0015 0015 0015 0015 0040 0015 0040 0015 0015 0015 070A
See less See more
Unfortunately I have a MX-500, not a Pronto. So those codes don't do me much good. :(
1 - 5 of 5 Posts
Status
