Status
Not open for further replies.
1 - 1 of 1 Posts
The replacement engine for my HLN 5065W is here, and Best Buy is coming Saturday to install it. Hopefully this will fix the green splotch problem I've been having (see this thread ).
Is there anything I should know or watch out for while the tech is installing it? The last Best Buy rep that came out didn't seem all that knowledgeable about the sets, and I'm frankly a bit concerned.
Also, does anyone know whether the replacement engine is likely to contain a board with the discrete code upgrade, or if there is some way I could check? It would be a nice added bonus to have the green splotches go away *and* end up with the discrete codes!
1 - 1 of 1 Posts
Status
