Status
Not open for further replies.
1 - 4 of 4 Posts
For some reason when I hook up my Samsung DLP to my PC with a DVI cable it only displays 800 x 600 resolution. When I go into display it doesnt let me change the resolution any higher.
What can I do to get a better Resolution? Do I need a special Driver?
Powerstrip doesnt seem to work right either. Im lost.
Thanks!!
Kevin
click on the "advanced" button on your display properties. on the "monitor" tab, uncheck the "hide modes that this monitor cannot display" box, and set the refresh rate to 60 hz.
go into powerstrip & set the resolution to 1280x720 @ 60 hz.
Discussion Starter · #3 ·
Thanks for the reply!
I have already tried that. When I go into that Res, the screen zooms in os much that i cant see the start menu.
I can move up and down like on adobe reader but that looks crappy. How can I make it fit my 43" screen?
Kevin
1 - 4 of 4 Posts
Status
