Status
Not open for further replies.
1 - 9 of 9 Posts
I Just ordered a Samsung DVD-HD931 DVD player with the DVI out to use with my Sony KDF-70XBR950.
First, does the Samsung DVD-HD931 DVD player come from the factory with a DVI cable in the box?
If so, is it a DVI-D cable or DVI-I cable and is it a single link or dual link cable?
Will the Samsung DVD-HD931 DVD player play the following:
DVD-Audio discs
Super Audio CD (SACD) discs
DVD-RW discs (recorded in DVD Video Recording mode)
DVD-RAM discs (recorded in DVD Video)
Windows Media Audio compressed audio files that have been copied onto CD-R/RW discs
CDs burned in the video CD format (MPEG-1)
Does the Samsung DVD-HD931 DVD player have a 6 channel audio decoder (separates audio into up to six true channels: front left and right, front center (for dialogue), two rear (surround) speakers with discrete wide-band signals, and a subwoofer?
Does the Samsung DVD-HD931 DVD player come with a Universal Remote?
Any accurate information will be much appreciated.
Thank You.
Let me answer what I can
Now they do, but I believe that is only for Nov and later build dates.
DVI-D - Sammy only produces digital out
DVD-Audio discs
no
no
Have not personally tested but others here say yes
Not a clue. Would never use one
dunno, i use mp3
Nope. almost a dealbreaker for me
as far as my understanding, that is up to your receiver. it has digital outs but any good dvd player lets the receiver decode.
you don't want to touch that remote. get something else and throw it away in a drawer.
wow. a lot of no's to you answer. might not be the player for you. sorry.
- jb
Discussion Starter · #3 ·
mrkaos, thank you for your quick reply and information.
Do you know if the DVI-D cable included with the Samsung DVD-HD931 DVD players is single link or dual link?
I understand that a single link cables will only support up to 1280 x 1024 resolution, whereas dual link cable supports up to 1920 x 1080 resolution, so am I correct to assume that a dual link cable is required for 1080i?
Corvette,
Honest opinion...I would advise you avoid the HD-931. I had it for about 2 months - for the DVI output with my Sony GWIII (KFWE50610).
Returned it due to major black crush issues - some dark scenes in movies were almost invisible. Also some color over sampling issues.
If you really feel like trying it out - make sure you have a no questions asked return policy.
After returning the HD-931 - I've cycled through a Denon DVD-2200, a Sony NS725P and finally found a mint Denon DVD-1600.
The 1600 is light years ahead of the Samsung, considerably better than the Sony, fairly identical video quality with the 2200 - and a lot cheaper than it.
I think it will take at least 12 - 18 mths for really good quality and affordable DVI equipped players to hit the market.
Discussion Starter · #5 ·
RATS!....too late, bought it a few days ago.
I understood that the problems you describe were addressed by Samsung through firmware upgrades as was the Sony compatibility with the revisions to the KDF-70XBR950.
Seemed that the Samsung DVD-HD931 DVD player had the edge over the Bravo, which as i understand is the only other DVI player currently available.
Maybe I should have waited.
Fingers crossed hopping for no problems.
Don't worry - so far the 931 is the most problem free DVI player out there in terms of loading and playing discs. And no doubt the video performance will be a significant upgrade from what you've been using.
From what I heard, unless the 931 is connected via DVI to your TV you don't get the benefit of the pseudo up-conversion. My Toshiba HDTV only has component inputs.
Can anyone confirm this? If so, it'd be a waste for me to purchase with my current TV.
Very true.
If you are just going to be using component there are a lot of better and cheaper players out there. Even the DVI part is not worth it. Can't pass PLUGE.
1 - 9 of 9 Posts
Status
