1 - 2 of 2 Posts
My 6167 was working fine until we had a power failure. HDMI input works great, but composite, AV1, AV2, and AV3 video input is screwed. Green screen with lots of horizontal and vertical lines scrolling around. I can still make out pieces of the image, and the audio is normal. This is happening no matter what device I use for input. I used the same DVD player to test unit. The yellow video connectors get me a trashed screen, but the same DVD unit's HDMI gets me beautiful picture. Audio is still fine. Same with Digital TV converter. Works great on another TV, but video on the 6167 is trashed.
I haven't been able to locate an S-Video cable yet, so I will probably go buy one today to test that input for a good video feed.
Any suggestions. Samsung service says the video board is not a customer servicable part???
Thanks in advance for your input.
1. Did you have some decent power protection?
2. AV1, 2 & 3 are component?
3. Is he HDMI the only good input?
4. What's with this "Digital TV converter"??
This has ATSC & QAM tuners (and a CC slot).
5. All manufactures will tell you nothing, but the lamp is "serviceable".
(FWIW, the set is around four years old.)
1 - 2 of 2 Posts
