After updating my firmware, my set was also completely screwed up... I found a way around most of the problems, as it turns out you need to go through all of the modes and all of the inputs to correct the problems that the update causes.
Then the fun begins... the PiP will no longer function, the melody does not work and the reset functions (picture and sound) are worthless until you've gone through all of the modes on all of the inputs...
Does anybody know how to do a hard reset or a re-boot on the TV? I can't find anyway to restore back to before 1019, I think mine was 1014.
