1 - 2 of 2 Posts
Hello all, I just bought this DLP and this is my first post so I hope I'm posting in the correct location. I have a Comcast cable box with component cables going into the TV and a TOS link cable (from the cablebox) to a reciever. Everything appeared to be working fine, but I rented an "On Demand" HD movie and the audio did not match the video on certain, but not all, scenes. It appeared to catch up within 30 seconds or so. It was quite annoying. Is this a problem I can diagnose or solve?
Thanks alot everyone,
Howard
Your hook up should provide lip sync without a problem. Maybe it was just an "on demand" problem? Do you get it with other viewing? DVD? Normal cable? Sometimes it happens for most of us due to some broadcast issue, so unless it happens frequently and on all inputs, I'd consider it an on demand problem and call Comcast and complain. They might need to boost your signal if it continues.
1 - 2 of 2 Posts
