I have a Samsung HLN437W. i bought it from a friend after it stopped working. when i bought it the color wheel would make a very loud buzz, so i figured i'd replace it and it'd be good. before the new one came, the old one stopped working all together. whatever, hooked the new one up anyway, and it's not powering up at all. if i look through the lamp it just sits there. i spliced the two wires on the back for the switch, so i could see it, but no go. i checked for any loose wires, and the ribbon cable is in right. can anybody help?
also, when the old one was still powering up, i turned the tv on using mute182power to see if i could see a menu or anything, and that may be when the color wheel stopped powering up.
any help is greatly appreciated.
Josh
Josh
