1 - 2 of 2 Posts
I will try to make this quick:
Just purchased a new PS3 hooked it up to my Samsung hp-s4253 through the HDMI 2 port (HDMI 1 is occupied by cable box and works perfectly fine). Fired up the PS3, video worked great but no audio. I thought the HDMI port might be bad, so I moved the cable box over to 2 and it worked great. Hooked the PS3 back up to port 2 and boom, I get "Mode Not Supported". I have tried turning off the PS3 and turning it back on, changing ports, changing HDMI cables, etc and nothing seems to work.
I would really appreciate any insight. Thanks.
Fox
Fox
i got ps3 working by using a radio shack high performance hdmi cable
1 - 2 of 2 Posts
