  • Take part in a short activity and share your valuable opinion on new design concepts for AVSForum! >>> Click Here
Samsung HPS4253 picture mode issue
707 Views 2 Replies 3 Participants Last post by  omeletpants
Hi,
I just got a Samsung plasma HDTV(HPS4253) for CC.
i got two issues here need help:
1. If i use "INFO" button on the remote , the TV
shows that the picture mode is at so call "shop mode"
but from menu it only has "dynamic", "standard" and
"custom" mode . where is this "shop mode" came
from.
2. I am able to programm the "custom" picture mode
(contrast, brightness ,etc) however the TV seems not
be able to save it.
the scenario is that whenever i use remote to
switch off the TV and switch on later on.
the picture mode( contrast, brightness) goes back to
original factory setting.
Is it because of "shop mode" ?
TV input : comcast analog cable only.
thanks
See less See more
Status
Not open for further replies.
1 - 3 of 3 Posts
Hello I have the same problem, did you buy a floor model by chance? I did and I think that is what shop mode is a display mode that automatically changes any user changes to some preset, so that people can make changes to the tv when viewing it at a store and then having those changes discarded after a few minutes....it may be something that is has to be changed in the service menu though I don't know how to access it on this tv. I am going back to the store where I bought the tv from to see if they can help me. Hit me up if you find a solution.
Check and see if it saves settings in the other modes. Samsung had a problem with the 53 series not saving settings in all the modes
1 - 3 of 3 Posts
Status
