Hi All,
My friend Amy has recently purchased a Samsung HT-DB120 'all in one' home theater system. It was just what was being looked for, and an open box item (so cheap!). But, the only problem was that it came without speaker wires.
Unfortunately, it's one of these easy 'plug and play' systems, where the speaker wires that would have come with the system would finish in a plug designed to easily clip into the amplifier, instead of the two separate wires you would normally attach to the amplifier/speaker..
So, my question is, is it possible to wire one of these systems up using normal speaker wire? Or do I need to advise her to call up samsung to get the plugs she needs? Or can she get them from radioshack and wire them up herself?
I hope that makes sense, and any assistance would be appreciated.
Mike
Mike
