361 - 380 of 13204 Posts
You forgot to mention the display mode ([email protected]@bitdepth) and the picture mode they should select on the TV.
Samsung HDTVs have always been RGB 4:4:4 capable in (but only in) PC mode (a nice Standard or a horrible Entertainments mode, no CMS, only triggered for [email protected] despite the explicit manual PC labeling which is requred for the auto-trigger).
Per the Samsung instruction manual, what you want to do is go into your TV's menu and set HDMI UHD Color to On. Then you look at the test image to see if it is working as advertised. Refer to Page 145 of the JS9500 instruction manual for more information.
I do not think labeling the input 'PC' makes any difference and this step is not described as necessary in the instruction manual.
Also, you are mistaken; there was a big fiasco with their 2014 model TVs where every model that lacked the Samsung mainboard (T-GFP8 or T-GFP9) was unable to display RGB 4:4:4 and still are unable to do so. 4:4:4 has never been a problem at 1080p resolutions or 4K @ 30 Hz, but it has been a big fiasco when it comes to 4K @ 60 Hz for some reason. There are so many manufacturers having problems getting a full RGB 4:4:4 signal @ 4K/60 Hz. Only LG and Panasonic seem to regularly get this particular functionality right.
The only Samsung 2014 models with this mainboard were all HU9000 units and all HU8550 units until August 2014 when they switched to manufacturing the HU8550 models with a third party Novatek chipset (T-NT14). All Samsung 4K TVs with Novatek T-NT14 chipset are unable to do RGB 4:4:4 @ 4K/60 Hz.
And because only the HU8550 and HU9000 models were the only models to use the Samsung T-GFP chipsets in them, the Samsung HU6000 and HU7000 series models lacked RGB 4:4:4 capability despite having the functionality explicitly promised in the technical specifications manual on Samsung's website for these models.
This is why we are all so concerned about Samsung pulling a repeat in 2015, as the wording in the manuals for their 2015 models is the same as the wording for their 2014 models: in other words, they could be lying, just like they lied in 2014, and the only way to know for certain is for someone to actually test out the functionality. I actually purchased a 2014 Samsung model (HU8550) and was forced to return it to the store after I learned Samsung was deceiving its customers by not delivering this functionality as advertised. There were a bunch of us who had this problem last year because Samsung made the switch to manufacturing the HU8550 series with a chipset that couldn't handle full RGB 4:4:4 right before selling a bunch of units during holiday sales, and we had purchased the sets based on the Samsung user's manual promising that 4:4:4 @ 60 Hz was supported
I don't personally own a JS9500, I just stepped in to this thread read some specific posts (but started to pick my nose into the discussion :rolleyes:).
It did for several years (4, at least, I can't remember exactly, may be starting from A- or B-series up until the non-UHD models of the H-series?), PC mode was mandatory to get 4:4:4.
But now I realize I never checked 4k review units at [email protected] becuase my laptop doesn't have HDMI 2.0 :rolleyes: I didn't think the frequency will make a difference here. Thank you for the information.;)
Has anyone hooked this TV up to a PC yet with a HDMI 2.0 graphics card (Nvidia GTX 900 series or Titan X) and had a look at this color pattern test?
If you view this image on your TV with your Windows DPI settings @ 100%, you can see if 4:4:4 (Full RGB) is working. (make sure you right click on the image and select view image so you see it at its full resolution in your browser window -- otherwise the test won't work as it should. AVS Forum makes the image smaller when you view it in a post like this one)
The bottom two lines of text on the red and blue backgrounds should be readable. If the letters are broken up it means 4:4:4 isn't working.
I'd really like confirmation on this because last year Samsung promised this functionality on their TVs and failed to deliver. There's no way to know if they're upholding their promise on their 2015 model TVs until someone tests it.
Can you take a picture so we can see the red and blue lines being displayed on your set?
This subject was "beat to death" and resolved on this or another thread on the forum during the last couple weeks. It was tested and "concluded that they were upholding their promise".
Suggest you try reading the threads rather than just "rolling a grenade into the room".
  • Like
Reactions: timc1475
I won't be convinced until I see an image of someone displaying this test pattern on their display with the text in the blue/red bars clearly visible.
So far I've only seen one image of this test pattern running on a JS9500 and it was at such a low resolution and so far away that you could not make out any of the text in the test pattern, so you could not see if the 4:4:4 was working or not, defeating the entire purpose of someone taking a picture of their TV with the test pattern on it. I've only seen that one review on HDTV test claiming it worked, but without any evidence backing it up.
There were too many people who just randomly jumped into the threads about this issue on the NVIDIA forums last year with the 2014 models, saying "Guys! Guys! I got a magic Samsung TV that has 4:4:4 working!"
Then we'd ask them to take a picture of their TV showing the test pattern, and sure enough, it actually wasn't working and the blue/red text was garbled in the picture that they posted.
The only way to know if it's working or .not is for someone to take a nice high resolution close up picture of that test pattern, specifically the bottom two red/blue bars which the text breaks on any display not showing 4:4:4.
I'm not just going to trust someone claiming it works without a picture backing up their claim after seeing so many blatant displays of incompetence last time around. No sir-ree. I'm not going to drop a few grand on a TV again just to be tricked by false reports of 4:4:4 working again. I want some visual proof that this issue isn't present in Samsung's 2015 models before I buy in.
Here are some examples some owners of Samsung's 2014 models took of this test pattern running on their displays:
http://i.imgur.com/0k6ncnE.jpg
Note how you can see that because they did it properly, we can all see for ourselves what the text looks like on their screen, and we can tell it looks screwed up @ 60 Hz.
Look at what the text in the blue and red stripe sections looks like on a 2014 model Samsung 4K TV:
http://i.imgur.com/CrBOK9Z.jpg
A picture like these on a JS9500 is what I'd like to see so we can put this to rest.
Whow. That's garbage. What chroma resolution is that 4:1:1?:p My 1080p TV doesn't show full 4:4:4 but I can still read that text (even if a little harder than the rest of the test pattern). It doesn't look like a simple chroma resolution halving but more like a software bug (not "optimization" but error).
If you have a 1080p TV it probably does display 4:4:4...
4:4:4 was never a problem with 1080p TVs and even the most budget random Walmart cheapo brand from the early days should display it properly. I have six 1080p TVs of random sizes, brands and models from Toshiba, Sony, Samsung, etc. and they all support 4:4:4 right out of the box.
So with a 1080p TV you could just assume it would work fine if you hooked your computer up to it.
That's why it's so annoying that this is continuing to be such a debacle for 4K resolution TVs.
See Post #50 on page #2 of this thread. I posted 2 pictures of 444 working at 60hz. The key was to have the Device Type set to PC.
Thank you. I felt very concerned and would not have been able to sleep until Wigglywaffles was satisfied. :)
Vendor
Good, it works. Thanks R0MM.
And I just noticed this guy's post:
Ten years of viewing here and 2015 is the first year that I recall the current obsession of 4:4:4 Chroma at 60Hz, it's not likely anything less carries SD Turdvision as a result does it? Can anyone here view real content without a test graphic and truly tell the difference?
^ There is an obsession with 4:4:4 chroma now because TV manufacturers have been bungling it with their 4K TV implementations, and many buyers of 4K TVs are PC gamers as the PC is the primary way to drive 4K content right now, and a lack of full RGB is very noticeable when a TV is being used as a PC monitor. It screws up all the text on the display; you don't need these very specific color patterns just to tell that something is off. Everything looks a little 'off' with 4:2:0 -- small black letters will have blueish hues to them in sections, etc.
4:4:4 was supported flawlessly by just about every 1080p TV manufactured so everyone could hook their PCs up to a 1080p TV just fine without this chroma problem so that is why it only became a big issue in 2014/2015 with the arrival of all these half-assed 4K TVs that lacked this functionality that every 1080p TV has been doing just fine for a decade. 2014 was the year all the PC gamers started jumping on the 4K TV bandwagon because the arrival of HDMI 2.0 on the 4K TVs and NVIDIA's GTX 900 series graphics cards having HDMI 2.0 meant 4K gaming @ 60 FPS was finally possible; a critical minimum for PC gaming. Prior to this 4K TVs could only drive 4K @ 30 Hz, and 30 FPS is an absolutely unacceptable framerate for PC gamers, so very few bought in to 4K TVs before HDMI 2.0 equipped 4K TVs arrived.
Many of us were burnt by Samsung last year so that is why we were extra paranoid in regards to the brand this year. This is solely Samsung's fault that they are receiving so much scrutiny this year, because last year they sold many of their customers a falsely advertised product which lacked this key functionality that we purchased because Samsung advertised it having this capability in the user manual.
Thankfully it seems that they aren't lying in their user manual for their 2015 models and it actually does work this time.
With UNH65HU9000's having dropped down to $1,700 on East Coast TVs I think maybe now I will wait until this time of year in 2016 to pick up a 65JS9500 because I want to see just how heavily they get discounted to make room for the 2016 models. $5,999 is too pricy but $3,000 could be doable ;) I can wait a year to save thousands of dollars, as $6k for a LCD, even if it is full array, is just highway robbery by Samsung.
Disregard rude replies from a particular individual to your legitimate question.
ROMM's photo is misleading in that the text is not part of the determination, it was there only to establish scale. I should have deleted all the text so that people who don't understand chroma wouldn't incorrectly think the text is deterministic. The 'test' in ROMMs photo was strictly the two squares which confirm 422 chroma with total disregard to text quality. that's why ROMM's low res images were good enough, you could see the colors of the squares.
Exactly, that's why stringent proof photos are required.
Turns out ROMM was forcing his js9500 into 422 chroma mode, that's why his photos returned a false negative. When he set up his TV properly, his photos confirmed 444 at 4K/60Hz, 422 @ 4K/24Hz. And the USB port is likewise confirmed at 422, a downgrade from the GolfP.
We've had numerous suggestions that the interested parties (with a 4K/60 4:4:4 fixation) start their own thread. Most of the posters on the specific model Samsung threads are more than tired of the subject. We've even had a moderator say we've had enough of it.
Unless the primary desire is to irritate others, I can't understand why you don't start a dedicated thread.
