Originally Posted by vud911 /forum/post/15474100
Nope, can't think of one TV out there that will let you control the TV through the LAN port, and frankly, I don't know why they would put such a impractical feature in the system, you will need a special program to send the signal, input the settings such as which IP you're going to send it to, etc. For debugging purpose and stuff, yes...real usage, can't think of any reason -- it is that much faster to locate the remote and shut off the TV.
You know already the LAN is very limited so don't need to point that out. Yes, it could be possible but why? Stuff like this increase the cost of production.
Why not?
For home automation purposes as said - for integrating my TV with a home automation server and tablet device as a remote - when I press "watch a DVD" or whatever other activity - for the tablet to have the ability to check the status of the device first, find out if its turned on already or not and send a command to the TV to turn on the device - over the LAN or other connection. Sure a Logitech (or other inexpensive universal remote) based remote can do this, but I am also wanting a system that can integrate my lighting, HVAC, alarm, and sprinkler system, possibly running CQC software to control said things.
When I disarm my alarm panel as I walk into my house, specific lights are turned on, the TV automatically turns on and is set to a specific channel, and so does my AVR along with its volume being adjusted to a preset level. When I go to bed at night I can create a "GOODNIGHT" button that turns the TV and other electronics off, turns off selected lighting, sets any selected ambient lighting I desire, sets the thermostat to a specific temperature and arms the alarm system. I could go on and on with practically an infinite uses of Home Automation where a larger system is used to control the TV and other devices.
A standard IR based remote cant do any of this based on a "disarm" command from a alarm panel (they are manual user input driven) or a "goodnight" command to do above said controls. So why would I want to go locate the remote to the TV to turn it off, walk around the house to find what lights are on and off, check the thermostat and set it, arm the alarm system when I can have it all done by a single press of a button?
The same manufacturers put RS-232 ports on the back of TVs for control purposes for exactly the reasons Im stating, but for whatever reason Samsung decided they werent going to offer the RS-232 port any longer, thus eliminating the control through their panels. I figured with the new addition of the LAN port that they may had been smart enough to had integrated it with some additional features. However, it's certainly possibly that they did not. I am simply wanting to find out before I purchase a second Samsung TV, because I can certainly get an LG that can, but as said, I already have a Samsung in my living room, and would prefer to keep the displays from the same manufacturer.
No need to question my purposes, as they certainly may not the same as yours. Obviously someone has bring these questions to the table, or we wont continue to have better devices. Why did Ethernet ports get put on a PC in the first place? Apparently 56k modems weren't the answer, and it seems that the "stuff like this increase the cost of production" seems to benefit everyone pretty well.
Its a simple question, can it be controlled via LAN or not?
