1 - 4 of 4 Posts
· Registered
When it gets to a certain level of darkness in the room, my Samsung 55" LED automatically dims the picture - and I don't like that. I've checked the menu's and I can't find how to disable this feature.
Can anyone with a similar model tell me if this is possible and, if so, how to turn off this auto-dim feature?
· Registered
Look for a feature called Eco-sensor or auto-sensor. Something like that. Try turning it off and see if that helps.
1 - 4 of 4 Posts
