1 - 3 of 3 Posts
Ok So im having alot of dificulty hooking up all my components.
Here is what im working with;
(TV) LCD Samsung LN46A530
(Reciver) Samsung avr720
(Cable Box) Rogers explorer 8300HD
Xbox 360 with HDMI
PS3
and the impact 5 port hdmi switch from tiger dierct to tie it all together.
Problems:
When I hook the ps3 and xbox up via the switch/splitter (leaving the cable box hooked direct to the reciver) the ps3 wont output 1080p. it looks fuzzy and clips out.
So I hook the ps3 up directly to the dvd port and try to run the xbox and cable box via the switch/spliter I get a DVI error from my tv saying somthing like"the tv does not suport hdcp" and it tells me to hook up everyting with component cabels which i dont want to do.
So with all that said here are my quetions.
How can I hook up my ps3 via the switch/splitter toi out put 1080p?
or
How can I enable hdcp on my television.
Note:
All my cables are 1.3 or at least thats what the said on the packaging.
Thank you for any and all help.
There was another poster with the same problem a few days ago - I think the issue is with the switcher. For some reason the PS3 doesn't like some equipment between it and the TV. I don't believe you can change HDCP - it's always there but some equipment just has issues during the HDMI handshake and won't sync up properly.
Discussion Starter · #3 ·
Issue resolved. I switched out the cables that I was using to hook up the ps3. Also when switching between signals on the switch I found out that powering everything down, switching singnals, and powering everything up works well, seems to be some issues with the relay of 2 1080p singals hitting the switcher.
Thanks for the pointer thow.
1 - 3 of 3 Posts
