I just got a Samsung LN46A580 and hooked it up in place of my hitachi plasma. I have HD cable through comcast. Its connected to my Onkyo TX-SR674 receiver via HDMI and the receiver is attached to the TV via HDMI.
When I press info the TV says its running at resolution [email protected] hz, which I believe is 720p. If I connect the cable box (via HDMI) directly to the TV it says ([email protected]) which I believe to be correct. One odd thing is that visually its hard to tell the difference. So my first thought was that my receiver is somehow downgrading the signal. So I hooked my upcoverting Onkyo DVD player to the same HDMI input on the receiver the cable box was using. The TV says its running at [email protected] So that confuses me, if the receiver were downgrading the signal, it should be doing that for any signal coming through, yet its not. Has anyone run across something like this before? I dont know if there is a problem with my TV or my receiver. Is it possible that the TV is misreporting the resolution when the cable signal is coming from my cable box?
This has me a bit baffled.
Thanks for any replies.
