Ok under the specs it says the component supports 1080p.
It does not say ANYTHING about what the HDMI supports.
So I called Samsung. The first person I talked to said yes this model supports HDMI at what ever the component outlets will support.
I call back.. next person says.. no it will not support 1080p in HDMI, only 1080i.. and "may" upscale it to 1080p.
I call back again.. next person says yes it will depending on the source. aka blu ray plays 1080p in HDMI.. it will.
I tell the tech that some HDMI's like the old TV I have .. only does 1080i. and I am wondering if this is because of the Tv itself that supports only 1080i or if SOME HDMI outlets only do up to 1080i. She says.. I'm not sure HDMI can be tricky.
Her advice was to hook up my ps3 and do each setting that works and if 1080p looks right or good on it.. then it is playing it.
I ask her.. what if the PS3 is sending it as 1080p and then the TV is downscaling it to 1080i.??
Shes says hrm I dunno.
I then talk to her about how there is no way on the LNS4695D to look in the menu and see what resolution you are at... exept for in the pc mode when you have it hooked up to a pc..
So the question is... How do I know if I am getting a true 1080p signal to my TV from the HDMI...?
Especially since it can be downscalled to 1080i and I cant view what res the TV is showing through a menu!!!! AND because even though the PS3 or different blu ray may be saying the blu ray or ps3 is sending it in 1080p but the tv might be downscaling it to 1080i.......
I am very angry that these techs do not know about thier product.
I do not have it yet I have it on delivery but I was thinking of switching to the Sharp AQUOS LC46D62U . But the Banding talk scares me.
I dont know what to do, or how to figure out what the Samsung is REALLY doing.
I need help.
I need help.
