Status
Not open for further replies.
1 - 2 of 2 Posts
· Registered
Does anyone have experience with the product? It is the only product of its kind that I have found, but would like to know of any alternatives in that approximate 17"-16:9 size.
Thank you very much
Rich
· Registered
I work for a major medical company that uses an OEM version of that panel for use in endoscopy surgery (that's the surgery that do entirely by video through small tubes implanted in the body).
The surgeons did not really like them until Samsung came out with the 170MB which is much better especially with black level.
They took the TV tuner out in this model, but the PIP function is still there are works pretty well.
The speakers are in our model, but we don't use them - however they sound suprisingly good.
The case looks space-age and holds up well. The circular stand we fold flat against the monitor and they use the front of it to move the panel around on a boom arm.
Hope this helps,
drewman
1 - 2 of 2 Posts
Status
