1 - 3 of 3 Posts
Discussion Starter #1
I have a Samsung HP-R4272 plasma. The set is just over 2yrs old (out of warranty) and has completely stopped working. I was watching a program when the entire screen lit up with every color of the spectrum, then went black with a red dot in the middle, then entirely dark. That was it, no more plasma.
The screen does nothing when power is turned on, no blink, no illumination period. There is some form of trouble code, the blue Samsung indicator will flash 3-times when you attempt to power it on. Anybody know where I can reference this trouble-code?
Any suggestions where to go from here? Are plasma repairs common and something I can have serviced through a local shop? I’m very disappointed at this point. A 2k dollar set shouldn’t last only 2-yrs…
All comments appreciated…
If you can get thru to the right people at Samsung tech support, they may still fix it as part of warranty. They're pretty good at helping customers with sets just out of warranty. Good luck.
1 - 3 of 3 Posts
