5A breaker. That's not on a house wiring panel, is it? Most house circuits are 15 amps.
If it IS a house breaker, do you have something else running on another outlet on the same circuit? We have an induction cooktop on the same 30A circuit as the garage door opener. If I come home and hit the remote and the door stops about a foot up, I know my wife's cooking something.... and is probably upset that she had to reset the breaker. Probably need to run a second circuit, one of these days.
You'd need to look up the power requirements for that set, but 50" Plasma should be a little south of 300 watts. A 5 amp breaker at 120V would have to be subjected to north of 600 watts to trip, but that's the total of all things plugged into the circuit and running.
If you're sure nothing else is on that breaker and it keeps tripping, then either the breaker's bad (first place I'd look) or the TV is drawing more current than it should, indicating something wrong, somewhere, such as on the power board.
Rereading your post, if the mere act of plugging it in trips a breaker no matter where in the house you plug it in, something's shorted. Stop trying until you can troubleshoot or find someone to do it for you.
Doc
Doc
