I have the above plasma set connected to our Comcast HD DVR (Motorola DCT6412) through a DVI/HDMI cable. I have been using this DVR for a few years with a Samsung DLP set without issue.
When I upgraded to the plasma set, I went into the DVR settings menu to force stretch to 480i content to avoid the vertical black bars when watching non-HD content in order to prevent any image retention.
About 70% of the time, when I switch from an HD channel to a non-HD channel, I lose most colors and the picture looks purple. It also seems I lose half of the lines on the screen (content looks as if it is being seen through blinds for lack of a better term). If I switch back to HD, I get the colors back but going back to non-HD has the same result. I usually have to turn the TV set off and then back on to get rid of the problem.
Does this sound like an issue with the TV set or the DVR? I can still return the TV so if this is the case I may do it. Thanks in advance for any suggestions.
