1 - 3 of 3 Posts
I have the following connected via HDMI.
Samsung PN58B860
Samsung BD-P1600
Denon AVR-590
I just set up internet connectivity to both the TV and the Blu-ray and I can't figure out how to turn off just the stinking TV after I start Pandora - everything shuts down.
Can someone tell me which device(s) is controlling this behavior and perhaps which setting(s) I need to change? It's maddening.
Discussion Starter · #2 ·
So, this is what I get from Samsung Tech Support:
Oscar V: Hello, I am a Samsung Technical Support representative. How may I assist you today?
Visitor: I have a BD-P1600 and a PN58B860 and have a question. After I start a Pandora session on the Blu-Ray I want to turn the TV off but when I do it turns the Blu-ray off. How can I control this behavior?
Oscar V: Let me check this for you.
Visitor: This is what I have via HDMI
Visitor: Samsung PN58B860 Samsung BD-P1600 Denon AVR-590
Oscar V: Did you connect the Blu-ray player to the receiver and receiver to the TV?
Visitor: Correct.
Oscar V: If you connect the Bl-ray player to the receiver and receiver to the TV and start Pandora and turn OFF the TV player will automatically go into stop mode.
Visitor: Yes ... the Blu-ray turns off ... this is bad and I want to correct this.
Visitor: Image Retention is something to be avoided and Pandora is a very static image.
Oscar V: If you turn OFF the TV automatically the player will go into stop mode and you will not be able to start Pandora.
Oscar V: You cannot change this function.
Visitor: What?!?! Are you saying I HAVE to have the TV on to listen to Pandora?
Oscar V: Yes, you need to turn ON the TV to listen to Pandora.
Oscar V: TV will act as interface between player and Pandora server.
Visitor: Do you agree that the static images of Pandora will cause Image Retention on the plasma TV?
Oscar V: No, you will not have any image retention on the plasma TV using Pandora.
Visitor: Ok. I guess it's official, thanks.
Oscar V: You're welcome. Is there anything else I can assist you with?
You need to go into the settings menu on both the tv and blu-ray and turn off cec-link, that way you can turn the tv off without turning off the blu ray player
1 - 3 of 3 Posts
