1 - 3 of 3 Posts
I recently bought a Samsung PN59D530 which I _think_ I'm going to keep. The manual claims that the wall mounting options are non-VESA compliant. Has anyone wall mounted this set? I know there is a PN59D550, but I don't know if the mounting holes are identical on that plasma.
Thanks in advance!
I mounted the same tv using mount item # 3900 from Monorpice.
No problems, very easy to setup.
Does your tv have any buzz/hum issues? I have a loud directional buzz when standing directly center screen.
Even though the manual says that the TV isn't VESA compliant, that doesn't necessarily mean that you can't mount it.
VESA compliance usually refers to a standard that companies use as a reference (ie. 100x100, 200x200, and so on)
Chances are your TV just has a custom measurement. Maybe something like 450x230 or something like that. There are still a lot of companies that have the right equipment to make it work. Try the TV mounting solutions by Kanto. They use bracket arms on the back of the TV that will slide left to right, so you can adjust them to fit your specific hole pattern.
Hope this helps..
1 - 3 of 3 Posts
