1 - 3 of 3 Posts
This plasma that I purchased on July 10th has significant burn in where the left side of the screen is much lighter than the right side.
What should I do? Can I run the burn in DVD to wipe out the IR or will I need to return the set? I have tried using Samsung's burn in removal tool that scrolls black to white for about 30 minutes and it does nothing for the problem.
you might have to run the scroll bar a little longer then 30 min's also i hread
if you have a white snow screen this will clear it up or try the dvd.
maybe some body else with a little more knowage can help you better
1 - 3 of 3 Posts
