Status
Not open for further replies.
1 - 6 of 6 Posts
Has anyone had their TS-160 lockup to where you need to remove power to get it back? It happens occasionally, but last night and today whenever I try to access the Chicago Fox HD channel it freezes.
Thanks for any info.
Pat
Discussion Starter · #3 ·
Sorry for the confusion. I have directv, but only watch the DT versions of local channels via the OTA. Fox is the only channel acting funny and it just started.
Thanks for the help.
Pat
Premium Member
Yep, had it happen last night during "CSI"(OTA-DT) - it was coming out of a commercial.
Had to unplug it so it could re-boot. A couple of weeks ago it was "ABC".
Dave
Someone in another thread stated if you take out you zip code it might solve the problem. You will lose programing info I think? I also think the unit has to reboot? Good luck.
Happend to me too. Turned to FOX 32-1 and box locked up. Did the unplug reboot but when box came back on it was still on 32-1 and locked up. So, did reboot again and as soon as the process was done I hit the channel up button to get it off 32-1 and the it worked. So it seems like it was the PSIP info from Fox 32-1 that was the problem. Later.
1 - 6 of 6 Posts
Status
