Status
Not open for further replies.
1 - 5 of 5 Posts
My new Samsung T-160 with the latest software downloaded works great. Benq 46 plasma accepts all connections from samsung including component s video etc., except DVI. I have set all the switches on the Samsung and Benq 46 in every possible combination. Still no DVI signal coming through. The plasma does not register in any way that it is getting a DVI signal from the T-160. Any suggestion
My owner's manual on my display also said to turn on the TV first.. then the DVI device. Sounds like some handshake needs to take place for pix to start.
Discussion Starter · #5 ·
Andrzej yes I have set the switches that way. JustJalone Doesnt seem to help but now at least it says searching. Matt cable appears to be a meter in length. Another note I cant get the sharpness adjustment to work. It appears as though it is faded. Thanks for your suggestions
1 - 5 of 5 Posts
Status
