Status
Not open for further replies.
1 - 5 of 5 Posts
There are no learning remotes for this receiver. Samsung is not making discrete codes available. All in One and Radio Shack Kameleon will not control TS160 from other rooms.
And at this point in time no extra TX160 remotes are available.
You might think about that if you don't want to walk from TV room to TV room with remote which came with TS160!
Try a PowerMid? Converts IR to RF to send thru walls, and then back to IR at the receiver end (which is placed near the Samsung unit). Pretty much works the same as most RF remotes Ive seen, just a little bigger.
I use a Radio Shack remote, but I have no need to control from another room (yet). When I do, Ill be purchasing a PowerMid setup.
-Chris
I used a IR Repeater and used a learning remote in the primary room I watch the TS160 in, I use the original remote in my other room with a IR extender, works great for me. (50 ft away from each other)
Jim
1 - 5 of 5 Posts
Status
