Status
Not open for further replies.
1 - 4 of 4 Posts
Video Cropping Problem
I just got the samsung ts160. I ordered it becuase it outputs to DVI as well as 480i s-video at the same time. I need to 480i output to go to a dvd recorder to record programs and football games. The picture is cropped on the top and bottom and it just looks like crap - is it supposed to be cropped?
OTA Signal Problem
I am getting a 69% signal on my fox 6-1 and no picture from the sammy ts160. PBS comes in at 77% and has frequent dropouts. I have a Mitts HD STB and a Zenith 520 HD STB and get a great signal on FOX and PBS. Is this normal? Any suggestions?
Is there any suggestion for the video cropping problem mentioned here? I am using the DVI to TV, S-Video to Tv for non-HD channels, and composite A/V cables to VCR (which dosn't seem to work..)
Is there a way to overcome this video cropping on HD through DVI when these non-HD connections remain in place?
Also, does the 480/720/1080 switch have to be changed in order for the composite cables to work for recordcing on the VCR from the TS-160?
Thanks for any input (no pun intended)
1 - 4 of 4 Posts
Status
