Samsung TS160 Tuner Problem - Help
222 Views 2 Replies 2 Participants Last post by  FBurrow
My Samsung TS160 HD tuner suddenly hung. The TV picture went blank but sound continued. The tuner would not respond to input either from the remote or directly on the set controls - channels could not be changed - the tuner could not even be cut off.
I thought something had burned out inside and unplugged the unit. I plugged it back in to run some tests today and it seems to be working perfectly.
Has anyone else seen this before or had a similar problem - what is happening?? Is it overheating or is this just a quirk.
Status
Not open for further replies.
1 - 3 of 3 Posts
You are posting in the rear projection TV forum.
See the thread for the Samsung TS-160 DirecTV receiver at the top of the HDTV Hardward forum.
FYI-You may have to reset this box every once in a while. See you in the other forum.
Thanks Duffin - I got what I needed in the hardware forum
1 - 3 of 3 Posts
Status
