Status
Not open for further replies.
1 - 3 of 3 Posts
Premium Member
My Panasonic PD50 ED 42" Plasma has an HDMI input. The Samsung receiver has DVI out. I am using a DVI to HDMI cable provided with the HD Tivo I bought last year. I get no picture when I switch the output on the 360 to RGB/DVI using the "Output Mode" button on the front panel, as instructed in the manual. Am I missing a step or function somewhere?
Jack
Jack
Things to check/try:
1) Did you select the HDMI input on the TV?
2) Do you have another DVI device (like a DVD player) to test the cable and tv with?
3) Do you have the TS360 receiver's output resolution set to one that the TV can handle (if you're outputting 720P and your TV will only accept 480P, you will see no picture)?
Premium Member
Discussion Starter · #3 ·
Roger,
1. yes
2. Not yet
3. It's set to 1080i but I will double check that.
Jack
1 - 3 of 3 Posts
Status
