I just got a Harmony 550 remote and I am working on getting it going on my Samsung tv model number: (SamsungHLR-5087W) and while switching inputs when going between DVD mode and tv it is getting stuck on the antenna fuzzy screen input that can't be passed over by the tv. I don't think it should be doing this and I know it can be fixed I am just not sure how. What I am trying to point out is that my Dishnetwork VIP211 receiver is hooked up with component cables to the component 2 jack in the tv and the Toshiba HD-DVD A1 (HDA1) is hooked up with the HDMI cable. So switching between them the remote seems to be getting stuck on the antenna input and will not go past it without using the help feature.
Second I use the analog inputs on my denon receiver (DenonAVR-2801) and the only way I can select the input on the receiver to switch over to the analog inputs is pushing the button on the stock remote or on the receiver called (EXT.IN) and since it seems the denon remote does not seem to send out a signal to the harmony remote it can not pick up the button i want it to learn?
This is the first time I have ever used a universal remote like this and if I can't fix these problems I will have to return it because this is not want.
